TwinTurbo.NET: Nissan 300ZX forum - EGR is a good possibility, it could be sticking? >>>
Subject EGR is a good possibility, it could be sticking? >>>
Posted by ZUL8TR on August 26, 2015 at 10:35 AM
  This message has been viewed 361 times.
In Reply To Re: How did you clean the MAS ? The hot wire sensor >>> posted by monkeymantn on August 26, 2015 at 09:05 AM
Message You need to get to the vacuum hose that activates the EGR and when the engine is idling normal at that stage the EGR should be closed, it only opens at some rpm point above idle. Then place mouth/or hand pump vacuum on that hose and the idle should stumble. You can also first do a vacuum gage test and look at the needle for anything beyond rock steady at about 19 to 20 "Hg would indicate an issue. This vacuum test is old school but it does reveal a lot, been doing it for years. Here is a complete description of what vacuum gage testing will show:
[ http://www.atlanticz.ca/zclub/techtips/vacuum/ ]
Here is a pic of the back of a pulled Z32 engine, note the hose attached to the right side of the EGR then going under the passenger side of the intake plenum:
[ http://www.twinturbo.net/net/viewmsg.aspx?forum=general&msg_id=1015966 ]
Hope your EGR is ok a bitch to change unless the engine is out or some other arrangement that a fellow Z32'er knows?
ZUL8TR in Orlando,FL
