TwinTurbo.NET: Nissan 300ZX forum - Re: How did you clean the MAS ? The hot wire sensor >>>
Subject Re: How did you clean the MAS ? The hot wire sensor >>>
Posted by monkeymantn on August 26, 2015 at 9:05 AM
  This message has been viewed 453 times.
In Reply To How did you clean the MAS ? The hot wire sensor >>> posted by ZUL8TR on August 24, 2015 at 05:48 AM
Message I cleaned the sensor connectors and not inside the tube itself. Cleaning the connectors definitely helped the stability of the idle. However, I am hearing a vacuum leak at the center back of the engine. Sort of a gasp/sucking sound when I give it gas. I can't tell exactly where it is coming from. Possibly EGR? I'm not saying EGR is bad, but may be the source of the leak. Thoughts?
