TwinTurbo.NET: Nissan 300ZX forum - rumble turning right.
Subject rumble turning right.
Posted by MaxxAction on August 23, 2015 at 7:49 PM
  This message has been viewed 315 times.
Message So,
I have a rumble in my driveline/suspension when turning right. It feels like a weak/dry/worn u joint would feel in a dirveshaft, but only when turning right. Even mild turns like changing lanes on the interstate, I can feel it a little.
The car was aligned last fall, tires are wearing perfectly symmetrical, and I haven't hit anything like potholes etc. All 4 wheel bearings have been changed within the last 4 months, starting with the rear left because that is where I feel like this noise/sensation is emanating from.
The gear lube in the diff was changed when I put the car back together back in may after swapping the transmission. There appears to be no play in the axles, but I do have a bit of slop in the diff itself. All the bushings in and around the rear hubs/knuckles/diff/carriage appear to be in good shape, most of them having been replaced within the last four years, and no more than 20k miles.
Anyone have any ideas what else I might look at? Thanks.
