TwinTurbo.NET: Nissan 300ZX forum - oil pump diagnosis and 120k
Subject oil pump diagnosis and 120k
Posted by ZUL8R on August 21, 2015 at 10:08 PM
  This message has been viewed 258 times.
In Reply To Motor apart questions posted by Diplomat1 on August 21, 2015 at 05:08 PM
Message I think you will definitely need a new timing belt after using it for the wrap method. But good to replace even if you hadn't used it for that. I read OEM is a fine replacement here.
Check your cam seals to make sure they aren't leaking. I don't think anyone here will recommend skimping on the 120k unless you are ok with revisiting the engine soon to follow up on what you didn't do this time. If that were the case, I think new timing belt is most critical.
I don't know about oil pump diagnosis once it's out but found this video.
https://youtu.be/IbXsjLMJkjk?t=2m36s
Looks like you'd need feeler gauge, straight edge, and FSM. I'd send you my old one but I ruined it trying to take my crank sprocket off.
