TwinTurbo.NET: Nissan 300ZX forum - Easiest way to distinguish rod knock vs. other noise
Subject Easiest way to distinguish rod knock vs. other noise
Posted by -Grimm- on August 21, 2015 at 9:42 AM
  This message has been viewed 350 times.
In Reply To questions on what to look for with head off posted by Diplomat1 on August 20, 2015 at 06:21 PM
Message is to disconnect the coil pack on that cylinder, it should (nearly) silence the rod knock if it is coming from that cylinder.
If your head gasket is bad you would definitely need machining and oversized gaskets. If you are pulling it off you should have a shop check it while its apart. Decking is cheap (around the $50 range) and gaskets are reasonable. Wouldn't hurt to do both sides
As long as the heads are the same casting you can use them in place of each other (that being, between your old engine and new engine, not PS and DS)
1992 300ZX NA 5 Sp (Dead)
1990 300ZX NA Auto 2+2 (Dead)
1990 300ZX TT 5 Sp (Stock Turbos) (Est. 400 HP)
1990 300ZX TT 5 Sp (GT600R) (Est. 600 HP)
2004 G35 Sport 6MT (DD)
2008 Honda Civic (DD)
1969 Chevy C10 (Toy)
1969 Chevelle (Toy)
