TwinTurbo.NET: Nissan 300ZX forum - You're on the right path
Subject You're on the right path
Posted by spicyZ on August 20, 2015 at 8:17 AM
  This message has been viewed 274 times.
In Reply To Re: Its possible posted by Diplomat1 on August 19, 2015 at 12:09 PM
Message The other thing I'd check is the oil pan to ensure it's not dented. Especially since this is an engine that sounds like it had been sitting around for awhile.
Even the slightest dent in the pan can result in oil starvation... and I think you know what comes next :-/
In order I would do these things:
1) Inspect your oil pan for any dents
2) Check your timing belt, as you plan to do
3) If that all checks out, put a small amount of oil into the cylinders with low compression and re-run the test to see if those numbers improve.
-jb
