TwinTurbo.NET: Nissan 300ZX forum - Cas not working properly?
Subject Cas not working properly?
Posted by Diplomat1 on August 18, 2015 at 11:29 PM
  This message has been viewed 405 times.
In Reply To Cylinder head removal while motor in wngine posted by Diplomat1 on August 18, 2015 at 09:50 PM
Message I decided to try the cas test (key in on position and turn to hear injectors) and I got nothing . Only I heard something is when I would take the connector on and off and it sounded like fuel was coming in. I tested the connector while off the cas with the key on engine off and I get
1st pin) 5.04 volts
2nd pin) 5.04 volts
3rd pin) battery voltage
4th pin) ground
Is that correct? Also is the part that goes into the cam that sticks out the cas supposed too be freely? Just doesn't seem right. Any way to bench test it? Hopin maybe the cas went bad or something thanks
