TwinTurbo.NET: Nissan 300ZX forum - Also, a failing PTU will allow the car to start when cold
spicyZ
on August 18, 2015 at 10:22 AM
A couple of things
posted by spicyZ
on August 18, 2015 at 10:21 AM
You might even get a little way down the road.. but when it heats up, it fails again. Been there, done that.
-jb
Car shut off won't start need help fast
Diplomat1
11:49:24 08/17/15
Re: Car shut off won't start need help fast
Diplomat1
12:16:16 08/17/15
Check and / or clean CAS connector. If all seems
ttz'in (norcal)
16:19:01 08/17/15
Re: Check and / or clean CAS connector. If all seems
Diplomat1
18:20:12 08/17/15
Bad news update knocking noise plus low compression
Diplomat1
00:54:57 08/18/15
A couple of things
spicyZ
10:21:13 08/18/15
Also, a failing PTU will allow the car to start when cold -
spicyZ
10:22:33 08/18/15
Re: A couple of things
Diplomat1
10:59:29 08/18/15
when it runs for that couple seconds is it rough or fairly
YlwPrlZTT
17:02:05 08/18/15
Re: when it runs for that couple seconds is it rough or fairly
Diplomat1
18:38:17 08/18/15
Sounds like there an mechanical issue. Bad compression, rugh
YlwPrlZTT
21:07:31 08/18/15
Cylinder head removal while motor in wngine
Diplomat1
21:50:49 08/18/15
Cas not working properly?
Diplomat1
23:29:42 08/18/15
Yes the CAS pin should spin freely (CAS side)
-Grimm-
10:49:35 08/19/15
Its possible
-Grimm-
10:50:32 08/19/15
Re: Its possible
Diplomat1
12:09:46 08/19/15
You're on the right path
spicyZ
08:17:58 08/20/15
