TwinTurbo.NET: Nissan 300ZX forum - Re: Check and / or clean CAS connector. If all seems
Subject Re: Check and / or clean CAS connector. If all seems
Posted by Diplomat1 on August 17, 2015 at 6:20 PM
  This message has been viewed 443 times.
In Reply To Check and / or clean CAS connector. If all seems posted by ttz'in (norcal) on August 17, 2015 at 04:19 PM
Message I am hopin it is a connection issue cause i feel like it happened gradually and not all at once. My biggest fear is I blew the motor. I got it started again but his time I had my foot on the gas pressing it about half way and it ran like crap and also the oil pressure gauge went high like 60+ psi. I don't know if that's bad or not. I am going to clean all connectors thoughrly and make sure I have good clean connection. Also my cas won't move even after I loosen the 3 10mm bolts it will not move for anything. How can I get it to move? I wanna turn and see if the injectors click because all I cam say is when I Take the connector off and put it back on the fuel pump will prime. Thanks
