TwinTurbo.NET: Nissan 300ZX forum - I just went through a clutch nightmare..
Subject I just went through a clutch nightmare..
Posted by Stanky on August 14, 2015 at 7:38 PM
  This message has been viewed 260 times.
In Reply To Clutch suddenly doesn't work posted by Tango Mike on August 14, 2015 at 05:08 PM
Message Similar to your issue actually(couldn't get the tranny out of neutral without grinding the gears).
My main question is how does the clutch feel? Does it seem like it's closer to the floor? Mine almost felt like it had air in the system, and it would grab right off the floor. I ended up buying a new Master and 1 piece clutch line to no avail. Ended up being my fork/sleeve assembly coming dislodged somehow.
Things I would do
-Check fluid like Sammy suggested
-Check to see if the slave is operating
-Bleed the system
-and what my issue was..check how the clutch fork looks.
Here is my post a couple weeks back
[ http://twinturbo.net/nissan/300zx/forums/technical/view/1152076/Update-on-my-clutch-problem-I-posted-yesterday.html ]
