TwinTurbo.NET: Nissan 300ZX forum - Try a fan shroud.
Subject Try a fan shroud.
Posted by flashstar on August 12, 2015 at 10:40 PM
  This message has been viewed 256 times.
In Reply To Koyo Radiator question posted by TurboTurtle (WaldorfMD) on August 11, 2015 at 01:37 PM
Message Maxima e-fans (within the Maxima fan shroud) work wonderfully with a Flex-a-lite fan controller on my NA.
Of course, this assumes you're only overheating while idling and not moving. Stationary cooling seems to improve dramatically with a fan shroud, regardless of the fans you use. Otherwise the fans cannot pull across the entire surface of the radiator.
Do you have room for the Maxima e-fans and NA radiator? They practically bolt up. Otherwise, I'd look at the Taurus fan with shroud.
