TwinTurbo.NET: Nissan 300ZX forum - ignition timing is different from sprocket timing
Subject ignition timing is different from sprocket timing
Posted by Z32CheekiBreeki on August 10, 2015 at 10:37 PM
  This message has been viewed 340 times.
In Reply To Re: Sounds like your timing belt might be off a tooth posted by Gumbercules on August 10, 2015 at 08:24 PM
Message you can set the timing to 15deg, but if the timing belt is off, your ignition timing will also be off once you set the belt right
like you set the ignition timing right for the wrong sprocket timing, so its wrong all together which may explain the severe lack of power as opposed to stanky's experience
