TwinTurbo.NET: Nissan 300ZX forum - Re: Re: O2 sensor was my main issue map light issues maby?
Subject Re: Re: O2 sensor was my main issue map light issues maby?
Posted by fleshworkstt on August 08, 2015 at 2:13 PM
  This message has been viewed 220 times.
In Reply To Re: O2 sensor was my main issue map light issues maby? posted by fleshworkstt on August 08, 2015 at 12:54 PM
Message Wow, well after digging in a junk yard i figured out that some on forced the courtesy light in to a plug on top of the plastic tube under yhe colum.So that pluged in to courtesy light and the three wire plug is now pluged in correctly.Also small brown plug at colum with long black and red wire not the obvious wires at the courtesy light go to key light...but mine has wat seems to be a replacements key and the wires are not black and red and are plunged in to a white connector at the column leaving my original brown connector with b\r wires dangeling.After finding a plug forced in the wring place not im concerned as to what is my key alumination plugged in to..??????
