TwinTurbo.NET: Nissan 300ZX forum - Re: also shot of oil in the cylinderes and retest >>
mboston
on August 08, 2015 at 10:40 AM
posted by ZUL8TR
on August 08, 2015 at 04:01 AM
Did a vacuum test, get between 19/20 at idle and 0 or so with throttle wide open, 12 psi when under boost.
Cylinder Compression results
mboston
22:28:50 08/07/15
Re: Cylinder Compression results
ttz'in (norcal)
02:40:12 08/08/15
ZUL8TR
04:01:58 08/08/15
Re: also shot of oil in the cylinderes and retest >> -
mboston
10:40:06 08/08/15
Re: Re: Cylinder Compression results
mboston
10:08:09 08/08/15
^2nd, leak down test it (n/m)
Stanky
03:43:11 08/08/15
Do a Leak Down Test..
Cjw3
08:56:06 08/08/15
Re: Do a Leak Down Test..
mboston
10:40:39 08/08/15
Leak Down Test Results
mboston
20:46:46 08/08/15
I think the next step is to look at the belt
Cjw3
09:09:35 08/09/15
Re: I think the next step is to look at the belt
mboston
19:02:40 08/09/15
First Off.. Look and see if the Marks Line up..
Cjw3
21:07:12 08/09/15
