TwinTurbo.NET: Nissan 300ZX forum - Do a Leak Down Test..
Subject Do a Leak Down Test..
Posted by Cjw3 on August 08, 2015 at 8:56 AM
  This message has been viewed 380 times.
In Reply To Cylinder Compression results posted by mboston on August 07, 2015 at 10:28 PM
Message The Cylinders in each bank are close in compression, which is good, but the total pressure is down which could be a Cam timing issue..
Do a Leak Down test.. Cam timing has no effect on this test, and this will tell you ( us ) the health of the Pistons and Valves..
If the Leak Down Test is good, then it's a Cam Timing issue
Cj
