TwinTurbo.NET: Nissan 300ZX forum - Re: Cylinder Compression results
Subject Re: Cylinder Compression results
Posted by ttz'in (norcal) on August 08, 2015 at 2:40 AM
  This message has been viewed 272 times.
In Reply To Cylinder Compression results posted by mboston on August 07, 2015 at 10:28 PM
Message If you haven't noticed any unusual smoking, it may not be piston rings. If 2, 4, & 6, are the low cylinders it may have something to do with the machining / valve work done on that head at rebuild.
Leak-down test should narrow it.
