TwinTurbo.NET: Nissan 300ZX forum - Re: O2 sensor was my main issue map light issues maby?
Subject Re: O2 sensor was my main issue map light issues maby?
Posted by ttz'in (norcal) on August 08, 2015 at 2:27 AM
  This message has been viewed 239 times.
In Reply To O2 sensor was my main issue map light issues maby? posted by fleshworkstt on August 07, 2015 at 07:55 PM
Message If " under dash light on drivers side " is actually the
foot well courtesy light, it uses the same style connector that the ignition key illumination light uses. That connector is fixed to the multi connector bracket on the steering column, and connector should be color coded. (you'll probably find it lost above, and to the right of the steering column )
Black / Red coded connector is for foot well courtesy light, same as passenger side.
