TwinTurbo.NET: Nissan 300ZX forum - First I'd really verify that there is spark from
Subject First I'd really verify that there is spark from
Posted by jzack on August 06, 2015 at 9:20 PM
  This message has been viewed 268 times.
In Reply To Car running on 3 cylinders after TT Swap posted by Z32CheekiBreeki on August 06, 2015 at 07:56 PM
Message each of those packs. A plug grounded and connected to the pack but not installed in the car - was there spark from each pack? Next, use an LED (NOID) test lamp to verify each of those injectors is being grounded by the ECU to fire. All injector's on the troubled side should also have constant +12v when key is on - use a volt meter to verify.
If all that is good - I'd next run a compression check on the troubled bank and see if something is up? Could do the compression check before above - whatever you prefer.
