TwinTurbo.NET: Nissan 300ZX forum - I'm a little Confused..
Subject I'm a little Confused..
Posted by Cjw3 on August 06, 2015 at 7:29 PM
  This message has been viewed 235 times.
In Reply To pin 115 02sen at ecu not getting ground? can I just make posted by fleshworkstt on August 06, 2015 at 12:23 PM
Message Pin 115 is the Line the ECU will take to ground to turn on the O2 Sensor Heaters..
If your ECU is not taking that line to ground, then you have an ECU problem.. Likely a Blown Transistor..
Are you asking if you can take Pin 115 to Ground to get the Heaters to Lite off.. Yes you can..
Cj
