TwinTurbo.NET: Nissan 300ZX forum - Usually corrosion on wires
Subject Usually corrosion on wires
Posted by FrozTTy on August 06, 2015 at 9:57 AM
  This message has been viewed 233 times.
In Reply To Intermittent rough running problem posted by 4-EZTT on August 05, 2015 at 04:15 PM
Message But I'd also bet you have one or more bad injectors.
-Remove all the wire connections you can get your hands on (especially injectors) and clean all the green corrosion off.
-Ohm test your injectors while you're in there, should be 10-14 ohms, anything else they need replacing.
-Change your fuel filter
-Change your engine temp sensor
