TwinTurbo.NET: Nissan 300ZX forum - Correct, not available in mineral only syn. (n/m)
ZUL8TR
on August 02, 2015 at 12:43 PM
And the 0w30 is more perfect than the 10w30
posted by not4resaleZ
on August 02, 2015 at 10:51 AM
Oil question- I know, use the search function!
madkiwi
15:05:27 07/29/15
Might find some useful info
Eagle7
15:52:13 07/29/15
10w30 is correct for your area....
Zuberman
17:31:59 07/29/15
Wrong (n/m)
not4resaleZ
07:34:54 07/30/15
Prove that 10w30 isn't the viscosity formula he should use.
Zuberman
22:33:45 07/30/15
Read Motor Oil 101 listed in the origional post. (n/m)
not4resaleZ
10:08:41 07/31/15
Bob isn't right about everything. (n/m)
Zuberman
11:52:37 08/01/15
As you can see from this link, Amsoil simply regurgitates
not4resaleZ
09:29:49 07/30/15
It's a service that Amsoil provides, and most other
Zuberman
22:45:42 07/30/15
I certainly don't hate Amsoil. A lot of people want to
not4resaleZ
10:06:28 07/31/15
Like I have said, the Amsoil application guide is convenient
Zuberman
11:55:00 08/01/15
In the context of your question, the 0w makes sense.
not4resaleZ
10:34:57 07/30/15
Because you know more than major oil manufacturers? wow
Zuberman
22:53:51 07/30/15
You really should read the article listed in the
not4resaleZ
10:01:19 07/31/15
Our TTs really like a heavier weight when warm
Polish
13:37:12 07/30/15
Also, if you wanted to for sure switch to 0 weight, Mobil 1
Polish
13:52:16 07/30/15
How do you define "liking" the oil? (n/m)
ttsmokin
14:17:48 07/30/15
My logic is TT engines run especially hot and
Polish
17:29:50 07/30/15
What is your oil pressure like?
ttsmokin
13:46:37 07/31/15
Staying at 5 weight is fine, but even
not4resaleZ
15:16:50 07/30/15
...the 0 weight is too thick for cold starts at 75 degrees F
Zuberman
22:57:44 07/30/15
yes (n/m)
not4resaleZ
07:12:48 07/31/15
Check the viscosity at 75F and notice that it is thicker>>
ZUL8TR
05:32:52 08/01/15
The reply line was a quote from not4. You are correct: the
Zuberman
12:00:47 08/01/15
Correct on constant vis, a perfect oil. Oops on the not4 (n/m)
ZUL8TR
03:24:34 08/02/15
not4resaleZ
10:51:15 08/02/15
Correct, not available in mineral only syn. (n/m) -
ZUL8TR
12:43:43 08/02/15
Do what you like. It's your Z. (n/m)
Zuberman
13:37:55 08/02/15
Are you taking into account his annual average cold-seaoson
Zuberman
23:01:46 07/30/15
It is cold, but not too extreme
Polish
00:12:55 07/31/15
Ok let's look at it this way, IF the Amsoil application page
Zuberman
00:30:23 07/31/15
Remember John and AMS? Cut the BS.
flashstar
02:37:06 07/31/15
Constantly hawking? LOL, that is bizarre. I utilized the
Zuberman
12:16:13 08/01/15
You're an Amsoil "Lifetime Dealer".
flashstar
02:53:22 08/02/15
I have already explained this several times: it was a matter
Zuberman
14:01:19 08/02/15
Solicitors are usually like used car salesmen...
flashstar
02:27:28 08/03/15
I won't bother you anymore, believe it. How is an e-mail
Zuberman
02:31:37 08/05/15
These pages are absolutely just using "stock" data they
Polish
02:51:43 07/31/15
Yes, and I do research environmental data such as the
Zuberman
12:03:53 08/01/15
I looked thru the attached link for 2015 model year
not4resaleZ
14:48:24 08/01/15
So you were going to give MadKiwi that link and then he was
Zuberman
14:55:12 08/02/15
No I would answer his question. You never did.
not4resaleZ
15:32:17 08/02/15
I did answer him: 10w30 is correct for his area. (n/m)
Zuberman
05:21:51 08/04/15
These discussions are pointless and pure opinion without a
Tanley
06:43:41 07/31/15
My opinion is that many people don't know enough
not4resaleZ
10:17:26 07/31/15
I have one for M1 5w50
Polish
11:12:49 07/31/15
Impressive. I used Quaker State 5w50 from 1994 to
not4resaleZ
20:36:21 08/02/15
Here's my UOA. RP 20W50 (the old Synerlec formula)
aquariuscsm
21:30:32 08/07/15
