TwinTurbo.NET: Nissan 300ZX forum - Re: no power to either head light
Subject Re: no power to either head light
Posted by madkiwi on July 25, 2015 at 11:30 PM
  This message has been viewed 297 times.
In Reply To no power to either head light posted by fleshworkstt on July 25, 2015 at 11:25 PM
Message Had a similar problem in my 1993 Pathfinder. Turned out to be the light switch/stalk. Replaced it, worked fine.
If you are SURE the headlight relays are good, then look at replacing the headlight switch. At least in the Z it is separate from the turn signal, in the Pathy it is all in one, more expensive that way.
