TwinTurbo.NET: Nissan 300ZX forum - Yes, you can have an injector that won't fire and still ohms
Subject Yes, you can have an injector that won't fire and still ohms
Posted by Tanley on July 25, 2015 at 9:15 PM
  This message has been viewed 294 times.
In Reply To You are correct that it is receiving 12V, but the way the posted by Tanley on July 25, 2015 at 09:04 PM
Message out in spec. If that is the case then it is most likely due to the injector getting gummed up or some other contaminate. Using the 9V may alleviate the problem, if it does not then you will have to pull the injector and have it cleaned/tested or replaced. Use the 9V multiple times like I described above to confirm you can't get the injector to fire before deciding to pull the injector.
