TwinTurbo.NET: Nissan 300ZX forum - Re: Valves hit piston during timing belt change
Subject Re: Valves hit piston during timing belt change
Posted by MaxxAction on July 23, 2015 at 12:48 PM
  This message has been viewed 306 times.
In Reply To Valves hit piston during timing belt change posted by Z32CheekiBreeki on July 23, 2015 at 10:44 AM
Message When you take the gears off, wrap the old timing belt around them to hold them in place while you impact them off.
When I did timing belt stuff, I would always back the crank up a few degrees off of top dead center so no pistons are in danger of hitting valves should the cam spin.
I think you are probably fine, put the belt and gears back together, and check your compression before you put the plenum, etc, back on.
