TwinTurbo.NET: Nissan 300ZX forum - My mistake; 15 degrees. I haven't tested injectors yet..
Subject My mistake; 15 degrees. I haven't tested injectors yet..
Posted by Mikester(Seattle) on July 22, 2015 at 1:13 PM
  This message has been viewed 316 times.
In Reply To Timing 10 ? should be 15 +/- 2. What do the injectors ohm?>> posted by ZUL8TR on July 22, 2015 at 03:54 AM
Message I mistakenly read NA should be 10 degrees in the FAQ. That is only true for 1996. After doing this, the car certainly feels a bit stronger, but still not 100%.
I am still using the older type injectors, not upgraded.
The timing belt was done by Nissan maybe 4 years ago. Hardly driven since. I don't suspect this is the issue.
After clipping injector wires, I did not see much of any corrosion inside, but I did feel a very waxy/sticky film on the wires. I cleaned them a bit before splicing in the new connectors.
My remaining ideas are to test:
Injector OHMs
MAF Sensor
Fuel Pump
Thanks again for the pointers and for pointing out my error on timing!
Unfortunately I busted a bolt off that holds the crank angle sensor. It's the one closest to the passenger side of the car. Not sure how exactly I am going to get the bolt out yet. Ideas?
