TwinTurbo.NET: Nissan 300ZX forum - Well, are they stock injectors?
Subject Well, are they stock injectors?
Posted by FrozTTy on July 22, 2015 at 8:39 AM
  This message has been viewed 358 times.
In Reply To The new Z is running rich, where do I start looking????? posted by Lone Z'er(CO) on July 21, 2015 at 08:40 PM
Message If they have been replaced, make sure you know what injectors are in there and you have the appropriate corresponding tune (ECU program) to run such injectors.
If you know these two items jive, then I'd look at ohm testing all 6 injectors. You might have one stuck open and is dumping fuel. You won't feel a rich misfire as you would a lean misfire.
If all injectors ohm within spec (10-14 ohms) then I'd suspect pinched injector O-rings.
