TwinTurbo.NET: Nissan 300ZX forum - Timing 10 ? should be 15 +/- 2. What do the injectors ohm?>>
Subject Timing 10 ? should be 15 +/- 2. What do the injectors ohm?>>
Posted by ZUL8TR on July 22, 2015 at 3:54 AM
  This message has been viewed 271 times.
In Reply To Lacking power in my 91 NA. What's next to check? posted by Mikester(Seattle) on July 22, 2015 at 12:26 AM
Message Injectors ever upgraded to the 93+ design? Maybe timing belt loose and skipped a tooth or 2? When serviced? Green corrosion bad - they need to be fixed or replaced. When you changed the injector connectors did you see any green corrosion on the clipped wires?
ZUL8TR in Orlando,FL
