TwinTurbo.NET: Nissan 300ZX forum - Some more info here:
ttsmokin
on July 21, 2015 at 2:35 PM
Sadly, I'm coming to the same conclusion...
posted by OverZealous (CT)
on July 20, 2015 at 09:52 PM
https://z32.wikispaces.com/R134A+Conversion
The FSM has quite a lot of info also
How can I check for an A/C leak while car is in my garage? (n/m)
OverZealous (CT)
22:06:59 07/19/15
You will need to add dye to the system and then use UV light
ttsmokin
00:30:30 07/20/15
Either dye and UV light or......
Zxpress
15:33:46 07/20/15
Why I suspect a leak
OverZealous (CT)
18:19:00 07/20/15
Not much to do about it til the car is running aside
BoneZ (MD)
21:08:57 07/20/15
OverZealous (CT)
21:52:31 07/20/15
It's a pressure relief valve
ttsmokin
14:34:35 07/21/15
Re: It's a pressure relief valve
Zxpress
17:21:35 07/21/15
Some more info here: -
ttsmokin
14:35:33 07/21/15
Thanks for the link
OverZealous (CT)
20:42:54 07/21/15
You most likely will need to have the
ZXRider
17:41:36 07/23/15
Thanks (n/m)
OverZealous (CT)
20:07:36 07/23/15
