TwinTurbo.NET: Nissan 300ZX forum - Yeah may invest in the pump will be doing gear oil next... (n/m)
WE350Z
on July 19, 2015 at 6:45 PM
If level when fluid just starts to overflow fill hole, it's
posted by ttz'in (norcal)
on July 18, 2015 at 05:22 PM
Manual Transmission Oil Change Question >>
WE350Z
00:32:43 07/18/15
I cut the bottle cap so a hose can barely be forced through
-Grimm-
14:48:50 07/18/15
Ok that helps. Is the 85W really thick? Would think it >>
WE350Z
16:26:18 07/18/15
Autozone should be able to help. If not this is a
ttz'in (norcal)
16:05:44 07/18/15
I got one pair of planks - do I just need to raise the driver >
WE350Z
16:31:37 07/18/15
If you have a pair, use both one for each front tire.
ttz'in (norcal)
16:40:17 07/18/15
Note: Looking in from the rocker panel behind
ttz'in (norcal)
16:48:13 07/18/15
Yeah that pump that screws onto quart bottles seems ideal >>
WE350Z
16:50:53 07/18/15
Redline synthetic MT90 has worked well for many.
ttz'in (norcal)
17:02:12 07/18/15
I had a set of smaller jack stands and like a true dummy I >
WE350Z
17:15:18 07/18/15
ttz'in (norcal)
17:22:21 07/18/15
Yeah may invest in the pump will be doing gear oil next... (n/m) -
WE350Z
18:45:39 07/19/15
Also trying Nissan MTF 85W API GL-4 first too see if it >>
WE350Z
17:24:23 07/18/15
If Greg & Seb say it works....It works.
ttz'in (norcal)
17:27:45 07/18/15
Just tilt up the passanger side with drive on planks to >>
ZUL8TR
07:08:12 07/19/15
Great! Will try this method sounds easiest to me... (n/m)
WE350Z
18:40:01 07/19/15
One last Q - how long of a hose do I need? (n/m)
WE350Z
20:26:10 07/19/15
I use a long snoot auto tranny >
ZUL8TR
04:12:44 07/20/15
