TwinTurbo.NET: Nissan 300ZX forum - If you have a pair, use both one for each front tire.
Subject If you have a pair, use both one for each front tire.
Posted by ttz'in (norcal) on July 18, 2015 at 4:40 PM
  This message has been viewed 453 times.
In Reply To I got one pair of planks - do I just need to raise the driver > posted by WE350Z on July 18, 2015 at 04:31 PM
Message Then jack @ center support under engine.
Sure level is good, but with drain plug close to rear of trans.
most will drain out and as long as you can pump in refill amount per service manual , you should be good.
With that pump on ebay it sucks fluid from the container of new fluid and then pumps it into wherever your changing fluid.
