TwinTurbo.NET: Nissan 300ZX forum - Use thick when possible, thin are usualy meant for signal or
Subject Use thick when possible, thin are usualy meant for signal or
Posted by f1ym4n on July 17, 2015 at 10:02 PM
  This message has been viewed 377 times.
In Reply To thoughts on which power to use off the ECU posted by ZiNnYc on July 12, 2015 at 11:06 PM
Message trigger wires that do not carry alot of current. If a 14ga wire is available, tap into that since it will be the best to carry the current and put the fuse inline with the splice.
If you do not know how a relays works, look it up online and youll see why its okay for a relay to have both thin and thick wires on the leads. it basically isolates the two circuits using an electromechanical switch
