TwinTurbo.NET: Nissan 300ZX forum - New Crank Angle Sensor Install - How do I align it?
Subject New Crank Angle Sensor Install - How do I align it?
Posted by Mikester(Seattle) on July 09, 2015 at 9:20 PM
  This message has been viewed 1201 times.
Message So I just bought a newer style crank angle sensor for my 91 NA, but I don't see anything in the FAQ about how to initially adjust when installing. I know when pulling out the old one, you want to mark the exterior so you know exactly how to put it back in, but when replacing it is there some other guideline to follow?
Also, does the rotated position of the shaft matter when you initially install? Is there a safe angle you can install to start with?
After that's done, obviously a timing light needs to be used to set the timing.
Thanks!
