TwinTurbo.NET: Nissan 300ZX forum - I remember seeing a post a while back saying to pour some
Subject I remember seeing a post a while back saying to pour some
Posted by Hiram on July 09, 2015 at 2:26 AM
  This message has been viewed 504 times.
In Reply To TTZ has sat for the past 8 years posted by CTZ21 on July 08, 2015 at 10:08 PM
Message kerosene or tranny fluid into the cylinders which is supposed to lube the cylinder walls and free up the rings. Let it soak in there a few days and then try to turn the crank bolt by hand to see if it is seized or will move. If it will move, cycle the cylinders a couple times, then do an oil change, and then try to crank it. Helps to save some initial startup wear which would be substantial with no lubrication in there after sitting so long.
