TwinTurbo.NET: Nissan 300ZX forum - Been there with that exact bolt broken
Subject Been there with that exact bolt broken
Posted by ThisIsSparTTa on July 08, 2015 at 8:54 AM
  This message has been viewed 538 times.
In Reply To Broken Oil Pan bolt, slight leak at the RMS posted by Zbullet on July 02, 2015 at 08:41 PM
Message Its going to leak no matter what you do with RTV.
I pulled the engine, the passenger side turbo and then the oil pan. Extracted the bolt and put it all back together. I was able to do that in a weekend, first day by myself.
If you can get the engine to tranny mounts loose on the passenger side, you can remove the oil pan by dropping the front crossmember. You won't be able to get the tranny mount bolts all the way out as they'll hit the oil tree (however, next time you have them off, you can cut notches for removal), but this should give you enough room to access the oil pan bolts.
