TwinTurbo.NET: Nissan 300ZX forum - Problem solved post in regards to bad, failed ptu...
Subject Problem solved post in regards to bad, failed ptu...
Posted by LivinTheDream on July 05, 2015 at 8:07 PM
  This message has been viewed 556 times.
Guys just wanted to post what the problem was in regards to this post bellow:
[ http://twinturbo.net/nissan/300zx/forums/technical/view/1151267/6-pack-not-sparking.html ]
Issue was a bad ptu. It was sending power but I guess just not enough. I saw slight variances between the none firing #6 coil packs power leads and the other 5. I THOUGHT IT STRANGE THAT only one cylinder would go bad as to the ptu failing completely. But God is good and I was able to stay mobile until I solved the issue.
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
