TwinTurbo.NET: Nissan 300ZX forum - Fuel manifold won't relieve pressure. Problem?
Subject Fuel manifold won't relieve pressure. Problem?
Posted by OverZealous (CT) on July 05, 2015 at 5:45 PM
  This message has been viewed 399 times.
Message So I pressurized the fuel manifold above the inlet plenum to test if the new OEM fuel hoses and clamps I installed were hermetic. They were but when I removed the test lines off the D.S. of the plenum the downstream pipes was still pressurized.
This implies either the pressure regulator or damper is holding pressure which doesn't seem right, or maybe it is?? Shouldn't air (or fuel) flow easily through the fuel manifold under minimal pressure conditions? Do I have a problem with one of these components?
OverZealous (CT)
My General posts (click)
