TwinTurbo.NET: Nissan 300ZX forum - What I need is a 16" long 1/8th inch drill bit.
Subject What I need is a 16" long 1/8th inch drill bit.
Posted by Zbullet on July 02, 2015 at 9:23 PM
  This message has been viewed 597 times.
In Reply To => BRB <= posted by OverZealous (CT) on July 02, 2015 at 09:11 PM
Message Yeah - to get that bolt drilled out and the hole re-tapped I'd have to drop the oil pan.
The leak wasn't that bad. Just enough to coat the bell housing with a thick layer of grime. I'm just a little nervous I might make it worse if I pull the seals and retainer for the fresh parts.
I didn't do the rebuild, so the bolt was likely broken by the previous owner upon installation of the pan. :-(
