TwinTurbo.NET: Nissan 300ZX forum - scratches head. both power leads get 14v...
Subject scratches head. both power leads get 14v...
Posted by LivinTheDream on July 01, 2015 at 8:31 AM
  This message has been viewed 486 times.
In Reply To #6 pack not sparking?? posted by LivinTheDream on June 28, 2015 at 07:00 PM
Message The only strange thing I see is that the ecu output to what looks to be the number 6cylinder puts out .1v and flickers to .0v while all other leads flickers between .1 and .2v. The output from the ptu is 14v across the board and the #6 coil pack connector sees 14v from the ign relay and the ptu. The ground shows .0035 v but the number 5 cylinder is similar while cylinder 1 and 2's ground lead reads 0v. Makes no sense why its not firing.
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
