TwinTurbo.NET: Nissan 300ZX forum - Re: Hmmm. That is interesting intel...
zromtech
on June 26, 2015 at 12:25 PM
posted by ConVerTT
on June 25, 2015 at 04:44 PM
I figured this out by reverse engineering the algorithms in the ECU code. Yes, the O2 sensors could be involved in this issue. You've determined that it happens only when the ECU is in idle mode, so I would suspect O2 feedback and/or AAC.
What else to check...
Stanky
00:18:22 06/24/15
Don't feel offended, but let me ask you this....
puchy
07:29:06 06/24/15
Compressed air to driver side, hockey puck blocking
Stanky
09:20:35 06/24/15
Check you idle stops. FSM section for TB setup. (n/m)
BoneZ (MD)
07:33:41 06/24/15
Will check tonight, thanks (n/m)
Stanky
09:22:17 06/24/15
EM-21 in the 95 FSM
BoneZ (MD)
19:19:40 06/24/15
Honestly i notice no change by disconnecting it
Stanky
19:34:00 06/24/15
Hell, that may be an issue.
BoneZ (MD)
19:49:52 06/24/15
if you changed smic piping you could mix up recirc and EBC
Dane (Houston)
09:53:50 06/24/15
I've been running the selin kit for a couple years now
Stanky
14:39:58 06/24/15
Re: I've been running the selin kit for a couple years now
Dane (Houston)
21:59:48 06/25/15
Have you tried it with just the TPS switch? (TPS sensor
ConVerTT
12:50:38 06/24/15
My NA is having this same issue. tried 2 TPS with clean pins
XTZ
18:09:08 06/24/15
So ....
ConVerTT
20:36:52 06/24/15
Can you run ECUtalk to check some parameters? (n/m)
OverZealous (CT)
17:45:25 06/24/15
Consult readings
Stanky
18:53:12 06/24/15
One more
Stanky
18:54:09 06/24/15
Re: One more
Dallas DamonZ
19:16:03 06/24/15
So...
ConVerTT
20:26:02 06/24/15
Correct!
Stanky
20:46:32 06/24/15
Awesome!
ConVerTT
23:20:02 06/24/15
Didn't realize it was open loop at idle
BlackholeZ
11:15:33 06/25/15
Actually, the ECU *does* have o2 feedback at idle
zromtech
13:39:07 06/25/15
ConVerTT
16:44:11 06/25/15
Re: Hmmm. That is interesting intel... -
zromtech
12:25:10 06/26/15
Should be able to disconnect the O2 and run at idle? (n/m)
BoneZ (MD)
12:29:51 06/26/15
yes, that should tell you if the O2s are involved (n/m)
zromtech
13:13:43 06/26/15
Ok great. Now how does this idle feedback interact
ConVerTT
09:03:08 06/27/15
Re: Ok great. Now how does this idle feedback interact
zromtech
10:31:23 06/27/15
Ok great. I was hoping that was the answer...
ConVerTT
11:43:47 06/27/15
Fuel pressure good, all injectors firing and ohm 12.5
Stanky
14:22:44 06/27/15
Re: Actually, the ECU *does* have o2 feedback at idle
Dallas DamonZ
00:35:48 06/26/15
Mine would idle at mid 14 afr for about ten seconds
xpwarrior
10:43:27 06/26/15
Re: Mine would idle at mid 14 afr for about ten seconds
zromtech
13:01:56 06/26/15
FWIW, Nistune allows you to enable O2 feedback
aliaZ
17:24:47 06/26/15
You can also do that with Tunerpro or even hex editing
xpwarrior
18:22:31 06/26/15
or ZROM Pro!*
zromtech
11:39:28 06/27/15
Appreciate the static pics but was hoping for transients vid
OverZealous (CT)
18:13:29 06/26/15
Please let us know exactly what the problem turns out to be. (n/m)
Zuberman
01:28:00 06/25/15
I've had similar issues, it ended up being a bad MAF
Zvil (FL)
09:36:15 06/25/15
Good point ...
ConVerTT
10:52:55 06/25/15
I have suspected my MAF to be questionable for years. Maybe
Zuberman
12:24:25 06/25/15
