TwinTurbo.NET: Nissan 300ZX forum - So ....
Subject So ....
Posted by ConVerTT on June 24, 2015 at 8:36 PM
  This message has been viewed 299 times.
In Reply To My NA is having this same issue. tried 2 TPS with clean pins posted by XTZ on June 24, 2015 at 06:09 PM
Message Normally, at idle, the ECU is running in open loop mode, meaning that the o2 sensors are not being used to adjust your AFR.
With the TPS unplugged like that, I think the ECU goes into closed loop mode, meaning that the O2 sensors are being used to adjust your AFR.
So I think that your o2 sensors are compensating for (too much) unmetered air or not enough fuel (injectors, clogged filter, low fuel pressure)
Old Yeller - 90 Slicktop NA (PGY)
