TwinTurbo.NET: Nissan 300ZX forum - What else to check...
Subject What else to check...
Posted by Stanky on June 24, 2015 at 12:18 AM
  This message has been viewed 471 times.
Message I posted this previously in the Tech section, but have ran out of ideas now, so was wondering if anyone would have any other possibilities to my Idle? 35 seconds into the video you'll see it almost hold an idle, and then lean out and fall on it's face.
https://www.youtube.com/watch?v=8DGEMVc5pAs
Things checked
- compression ok
- Tps .44v
- no codes
- ZERO boost leaks!(tested 3 times)
- timing good
- unable to adjust idle via screw with aac unplugged
- fuel pressure good
- cleaned IACV unit, no change
- cleaned both MAFS, no change
This idle is only after installing the inlet and intercooler piping, along with a new EFI harness. Car was tuned last year on stock piping, but I'm not sure if some bigger piping could throw things off like so..
