TwinTurbo.NET: Nissan 300ZX forum - Adding Stainless steel brake lines. Need advice
Subject Adding Stainless steel brake lines. Need advice
Posted by XTZ on June 28, 2015 at 9:16 PM
  This message has been viewed 592 times.
Message I'm adding Stainless steel brake lines to the TT. I had a hard time with loosening the rear passenger side hardline nut from the caliper.
I will have to fight the hardline that is attached to the bracket which is welded to the frame. It was getting dark,
so I was going to put it off until tomorrow 6/29. I tried a 10mm wrench, but it just rounds off the nut, and doesn't budge.
I used PB blast, but then added 50/50 ATF and Acetone to soak overnight..
Any advise on what I could do to make this go easier? I can barely get my hand and tools back there. I'll have to do the rear drivers side as well.
