TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: I need more Info than that..
Subject Re: Re: Re: I need more Info than that..
Posted by Cjw3 on July 01, 2015 at 7:23 AM
  This message has been viewed 813 times.
In Reply To Re: Re: I need more Info than that.. posted by TJSB on July 01, 2015 at 06:55 AM
Message here is a list of Codes I found in the Google Machine..
Looks like it's just pissed the Sol Actuators are missing.. It's not ( yet ) complaining about the Missing O2 Sensors..
Are you actually going to try and Fix this.. or sell it out of state and get a legal one to replace it.. ?..
Cj
P0100 - MAF Sensor
P0110 - IAT Sensor
P0115 - ECT Sensor
P0120 - TP Sensor
P0125 - ECT Sensor
P0130 - Front HO2S RH Bank
P0135 - Front HO2S Heater RH Bank
P0136 - Rear HO2S RH Bank
P0141 - Rear HO2S Heater RH Bank
P0150 - Front HO2S LH Bank
P0155 - Front HO2S Heater LH Bank
P0156 - Rear HO2S LH Bank
P0161 - HO2S Heater LH Bank
P0171 - Fuel Injection System Lean RH Bank
P0172 - Fuel Injection System Rich RH Bank
P0174 - Fuel Injection System Lean LH Bank
P0175 - Fuel Injection System Rich LH Bank
P0180 - Fuel Temperature Sensor
P0300 - Multiple Cylinder Misfire
P0301–P0306 - Misfire Cylinders 1–6
P0325 - Knock Sensor
P0335 - CKP Sensor
P0340 - CMP Sensor
P0400 - EGR Function
P0420 - TWC Function
P0430 - TWC Function
P0443 - EVAP Canister Purge Control Solenoid Valve
P0500 - VSS
P0505 - IACV-AAC Valve
P0600 - A/T Control & Communication Line
P0605 - ECM-ECCS Control Module
P0705 - PNP Switch
P1150 - Wastegate Valve Control Solenoid Valve
P1155 - Wastegate Valve Control Solenoid Valve
P1160 - Turbocharger Boost Sensor
P1220 - Fuel Pump Control Module
P1320 - Ignition Signal
P1336 - CKP Sensor
P1400 - EGRC Solenoid Valve
P1401 - Temperature Sensor
P1443 - Canister Control Vacuum Check Switch
P1605 - A/T Diagnosis Communication Line
P1900 - Cooling Fan
