TwinTurbo.NET: Nissan 300ZX forum - Re: Can I use M/T ECU on frmrly auto engine with 5spd trans?
Subject Re: Can I use M/T ECU on frmrly auto engine with 5spd trans?
Posted by Metacom on June 30, 2015 at 8:35 PM
  This message has been viewed 482 times.
In Reply To Can I use M/T ECU on frmrly auto engine with 5spd trans? posted by ZUL8R on June 27, 2015 at 04:52 PM
Message Heard a couple guys have problems getting ignition timing set to 15 degrees BTDC on 5spd swaps still using the original AT ECU.
Ahh.. hard to remember the details, something about the AT ECU would adjust the timing when in drive to smooth out the shifts. It was determined by the neutral switch on the tranny if I remember right and there was a way to bypass it...
