TwinTurbo.NET: Nissan 300ZX forum - it uses the stream of return fuel to pull fuel from the
Subject it uses the stream of return fuel to pull fuel from the
Posted by Zvil (FL) on June 28, 2015 at 1:12 PM
  This message has been viewed 345 times.
In Reply To Jet Pump posted by Denis on June 28, 2015 at 10:47 AM
Message passenger side, since our gas tank is a saddle style, once the fuel level is lower than the hump in the middle the fuel remaining on the passenger side would just be useless had not Nissan designed that venturi/siphon system..... bet the 370z guys are jealous, since they have a returnless fuel system they don't have this advantage.
____________________________________________________
"The dreaded 2nd windshiled wiper swipe when you turn it off its almost like tis showing you that it's boss, and it doesn't have to stop when you tell it to :("-College Boy
(discussion on ptu relocation)
"No good reason to put it there anyway. -Bernie (NoVA)
False -vorpalZ
False. -Bernie (NoVA)
You're correct, there are 3 good reasons -vorpalZ
Wow, right again, just remembered another, make that 4 -vorpalZ"
XD
