TwinTurbo.NET: Nissan 300ZX forum - One way is to disconnect the EGR solenoid connector and
Subject One way is to disconnect the EGR solenoid connector and
Posted by jzack on June 27, 2015 at 4:24 PM
  This message has been viewed 478 times.
In Reply To I have isolated a vacuum leak somewhere after the EGR posted by msb1987 on June 27, 2015 at 01:47 PM
Message then put a 10k resistor across the connector contacts. Fools the ECU into thinking the solenoid is still connected. Just fit the resistor into the plug and tape it up a bit. Fairly easy way to do this assuming the solenoid has no leaks?
Vacuum line source on the EGR valve can be removed and folded over then taped to seal it up. Just another way to do this too.
