TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: fuel smell from cc delete.
Subject Re: Re: Re: fuel smell from cc delete.
Posted by Bad Fish on June 26, 2015 at 11:39 PM
  This message has been viewed 426 times.
In Reply To Re: Re: fuel smell from cc delete. posted by EpiDeMiCc on June 26, 2015 at 06:32 PM
Message The fuel vapor is going to get in the cabin now no matter what you do as it is exiting under the driver seat. If you left the hard line running under the hood the fuel vapor would at least be venting away from the interior. The hardline can be vented to the intake to keep the fumes to a reasonable level. Again, do not remove the check valve. It's main purpose is to prevent fuel from flowing out of the tank in the event of a rollover. Removing it will do nothing to reduce vapors.
