TwinTurbo.NET: Nissan 300ZX forum - Re: pull plugs, ground verify spark. Check compression...
RRyderTT
on June 25, 2015 at 5:53 PM
pull plugs, ground verify spark. Check compression... (n/m)
posted by wickdGSXR
on June 25, 2015 at 05:03 PM
Thanks for the info, i'll definitely do that and let you guys know. I appreciate the advice.
Car backfires then motor dies while cruising at 50mph..
RRyderTT
12:56:01 06/25/15
First congratulations to you and your wife !
ttz'in (norcal)
13:25:23 06/25/15
Thank you!! Timing belt done in January 15' :)
RRyderTT
15:59:51 06/25/15
Life changing moment for sure..Enjoy ! (n/m)
ttz'in (norcal)
16:05:57 06/25/15
It was the CAS. Thanks again Stephen!
RRyderTT
17:21:00 06/27/15
Salute.. Now back to your son.. (n/m)
ttz'in (norcal)
11:21:01 06/28/15
wickdGSXR
17:03:00 06/25/15
Re: pull plugs, ground verify spark. Check compression... -
RRyderTT
17:53:43 06/25/15
