TwinTurbo.NET: Nissan 300ZX forum - You may want to remove that extra grounding kit to test
Subject You may want to remove that extra grounding kit to test
Posted by flashstar on June 23, 2015 at 2:37 PM
  This message has been viewed 241 times.
In Reply To Sorry I didn't look sooner. I see the big 3 write up page! posted by gman300zxtt on June 23, 2015 at 02:21 AM
Message Ground loops can form if you add grounding points (not saying it WILL happen).
My system uses 2x 225 watt RMS amplifiers:
I ran a 0/1 gauge ground from my alternator to my battery. 0/1 gauge ground from the stock transmission ground point to battery, and 2 0/1 gauge grounds from the battery to chassis. No issues with ground loops.
Extra 0/1 gauge positive from my alternator to + on battery (through fuse) and 0/1 gauge positives to each amplifier through separate fuses
For a much larger amplifier, I'd definitely go with true 0 gauge cables. Do you hear any static or noise when playing music?
