TwinTurbo.NET: Nissan 300ZX forum - Correct, you took the ground from the AM head
Subject Correct, you took the ground from the AM head
Posted by ttz'in (norcal) on June 22, 2015 at 7:12 PM
  This message has been viewed 236 times.
In Reply To Re: Reconnect the AM head unit ground, and if you want posted by gman300zxtt on June 22, 2015 at 05:46 PM
Message unit and connected it to the factory spade connector.
Connect that back to the crutchfield connector that plugs into factory connector, and if you want connect a separate ground from factory spade connector to head unit chassis or rear support bracket.
